@JoeBryant1 posted an Idea earlier about being able to create bookmarks from the features in a feature class / layer. It then got merged into this really old Idea: https://community.esri.com/t5/arcgis-pro-ideas/layer-to-bookmarks-tool-amp-bookmarks-to-layer/idc-p/946511
Seeing as the original Idea is from 2011, I don't think this will be implemented any time soon, but it seemed like a fun little project to implement myself...
The function in the following Python script will read a feature class or layer (honoring definition queries and selection) and create a bookmark file using the feature extents. The bookmark file can then be imported into an ArcGIS Pro map.
- The bookmarks can be named by a field or with an incrementing number.
- The features can be dissolved by a field (in that case the naming field gets switched to the dissolve field).
- The features can be buffered.
- You can specify the minimum length of the smallest dimension of the resulting bookmarks.
Using this function, it's easy to turn the script into a script tool, which is attached to this post (as zipped atbx).
This was a fun little project, and if it can help some people, all the better 🙂
import arcpy
from pathlib import Path
def _create_bookmark_dict(in_geometry, min_dist):
"""Returns a dict defining a bookmark for the input arcpy.Geometry object."""
e = in_geometry.extent
d = min([e.width, e.height])
if d < min_dist:
buffered_geometry = in_geometry.buffer((min_dist - d) / 2)
e = buffered_geometry.extent
return {
"type": "CIMBookmark",
"location": {
"xmin": e.XMin,
"xmax": e.XMax,
"ymin": e.YMin,
"ymax": e.YMax,
"spatialReference": {"wkid": in_geometry.spatialReference.factoryCode}
def create_bookmarks(in_features, out_path, name_field=None, dissolve_field=None, buffer_dist=None, min_dist=None):
"""Creates bookmarks from all features in a layer.
in_features (path to feature class as str / arcpy.mp.Layer object): The input features. If this is a layer, definition queries and selection will be honored.
out_path (str): Path of the output bkmx file.
name_field (str): The field used to name the bookmarks. Optional, default is incrementing number.
dissolve_field (str): The field by which to dissolve the features before creating the bookmarks. Optional, by default there is no dissolving. If both name and dissolve field are specified, the name will be ignored and the features will be named by the dissolve field.
buffer_dist: distance by which the input features are buffered, measured in the default units of the in_feature's coordinate system, important for small features. Optional, defaults to zero.
min_dist: minimum extent width or height, measured in the default units of the in_feature's coordinate system, important for small features. Optional, defaults to zero.
# dissolve features
if dissolve_field not in [None, "", "#"]:
in_features = arcpy.management.Dissolve(in_features, "memory/dissolve", [dissolve_field])
if name_field not in [None, "", "#"]:
name_field = dissolve_field
# buffer features
if buffer_dist is not None and buffer_dist > 0:
in_features = arcpy.analysis.Buffer(in_features, "memory/buffer", buffer_dist)
# create the bookmarks
if min_dist is None or min_dist < 0:
min_dist = 0
bookmarks = []
read_fields = ["SHAPE@"]
read_fields.append(name_field)
for i, row in enumerate(arcpy.da.SearchCursor(in_features, read_fields)):
try:
bm = _create_bookmark_dict(row[0], min_dist)
except: # eg null geometry
continue
if name_field not in [None, "", "#"] and row[1] is not None:
bm["name"] = row[1]
else:
bm["name"] = str(i)
bookmarks.append(bm)
# write bkmx file
out_dict = {"bookmarks": bookmarks}
f = Path(str(out_path))
f.write_text(str(out_dict))
if __name__ == "__main__":
in_features = arcpy.GetParameter(0)
out_path = arcpy.GetParameterAsText(1)
name_field = arcpy.GetParameterAsText(2)
dissolve_field = arcpy.GetParameterAsText(3)
buffer_dist = arcpy.GetParameter(4)
min_dist = arcpy.GetParameter(5)
create_bookmarks(in_features, out_path, name_field, dissolve_field, buffer_dist, min_dist)
