I am trying to export a report generated from a survey123 which was built using survey123 connect. The survey data collected is basic - just photos and comments, however there are c. 250 points and therefore 250 photos I want to export. There is only one record to export, so all 250 photos are associated with this record. Every time I try to export the report, it fails due to timeout at about 9m 30s. I do not believe there is an issue with the report template, as it exports correctly when tested with 3/4 points.
Any help with exporting this report, perhaps in batches, would be greatly appreciated.
Many thanks,
Annys
