Is there a way to delete attachment/photo in the Inbox? I wish to delete photos captured before but it seems there is no delete function.
I don't believe so, you can only add, not edit/delete per the limitation notes below:
https://doc.arcgis.com/en/survey123/desktop/get-answers/editexistingdata.htm#ESRI_SECTION1_47C2CB8342244924B1D99EBB35EAFFFE
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm#ESRI_SECTION1_8D52397BCD104F4AA79E610BC02D2761
This user indicates you can but I have not seen any method/notes to support it. Maybe another idea should be created:
https://community.esri.com/t5/arcgis-survey123-ideas/survey123-make-it-possible-to-update-or-delete-an/idi-p/1183199
Also, photos don't download in the Inbox when offline. The survey form is downloaded, but photos only load when the survey form is opened (so won't have the photos if device has no internet connection).
Please support these ideas to allow inbox viewing of photos ENH-000158507https://community.esri.com/t5/arcgis-survey123-ideas/support-offline-images-in-survey123-inbox/idi-p/1293958/jump-to/first-unread-message
