How do you set the default unit for in the measure tool in Experience Builder.
In my app I turned on the measure tool in the Map Widget. It is defaulting to Metric. I am not seeing any way to configure this through EB. Only option is to show or not show the tool.
I then assumed it would take the default unit from the map that is populating the map widget in the app.
This is also not the case. If I use the measure tool in the Map Viewer, it defaults to imperial. In the EB app it is defaulting to metric.
What am I missing?
