When converting coordinates from a .csv through the "XY coordinates to point" and choosing a different output location than the default .gdb ArcGIS pro freezes. Bug is reported.
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
What is the "bug". It would be useful
If you don't specify the full path to another *.gdb it won't work, unless you want a shapefile, then you have to make sure that you add *.shp to the file name
