Hii All,
I have loaded map using portal/portal item. Now i want to add/sync feature(point) on the same map, how can i add/sync, please help.
Hello,You can add the point graphic to the same map using below code snippet:
// create and add a map with with portal itemval map = ArcGISMap(portalItem)// add the marker graphic to the graphics overlaygraphicsOverlay.graphics.add(markerGraphic)mapView.apply { this.map = map// add the graphics overlay to the MapView graphicsOverlays.add(graphicsOverlay)}
// setup the red pin marker as a Graphicprivate val markerGraphic: Graphic by lazy { // creates a symbol from the marker drawable val markerSymbol = PictureMarkerSymbol.createWithImage(markerDrawable).apply { // resize the symbol into a smaller size width = 30f height = 30f } // create the graphic from the symbol Graphic(symbol = markerSymbol)}
Let me know if this helps?
