I'm new to S123 connect and want to make sure I'm following best practices.
Is it ok to leave bind::esri:fieldType blank?
Unsure the difference between the type column and the bind::esri:fieldType column.
Hi. Yes, it is OK to leave it blank. When you do, Survey123 Connect will automatically map the XLSForm question type to the appropriate Esri field type:
Sometimes, you want to set a value in the FieldType XLSForm column. Common cases include:
thanks for the great explanation!
