I need to export a few domains from a hosted feature layer but there does not seem to be a way to do this in ArcGIS Online or Pro? Please advise as Domain to Table Geoprocessing does not allow me to select the correct Input Workspace.
Exporting the layer should include the domain if you copy it into a file geodatabase, then you'd be able to use that in the Domain to Table tool. You could also just go to the feature service's URL, append a ?f=json and then extract the domains objects from the service definition.
Thank you @jcarlson - I did have it exported to a FGDB but for some reason it was not letting me select anything. Also didn't realize that the actual .gdb file could be selected as the workspace 😅 Thanks again.
