Hello everyone,
I am working on a Survey and need to hide the zoom in/out and home widgets from the survey. Does anyone have such experience?
Best Regards,
Mostafa
I believe the functionality to hide those tools will be available with the June 2023 update of survey123.
You can test it out at the https://earlyadopter.esri.com/
A new mapTools parameter can be added to the body::esri:style column of the XLSForm. There are 5 available mapTools values that can be specified by comma separating them:
Are there any updates to this? (hiding options on the map widget in Survey123 Connect)
I can't find the syntax anywhere.....
Thanks!
I found the syntax, so yay!
https://doc.arcgis.com/en/survey123/desktop/create-surveys/geopoints.htm
(doesn't seem to make any change on the web version of the survey, but at least I finally found the info)
-Martha
