I am taking advantage of the new dashboard Table element available with 11.1 by recreating a table originally scripted with sql in a MS Access database (not by me).
I have a set of facilities (unique points in a feature layer) that I need to join imagery flights to from a related, one-to-many table. But what I need assistance with is that the table needs to have columns for the last 10 years from Now, and each facility would have an X in the year column for flight that occurred.
Desired output:
| FacilityID | 2013 | 2014 | 2015 |
| 1 | X | X | |
| 2 | X | | X |
I've got some aspects figured out from this community's amazing knowledge, but how to generate the year columns is escaping me.
//add portal connection
var p = portal('https://portal');
//add site_p as fs to table filtered to major training sites = Y
var fs = Filter(
FeatureSetByPortalItem(
p,
'portalID1',
15,
['joinfield1','namefield2','locationfield3'],
false
"big_site" = 'Y'"
//add imagery data table
var rel_fs = FeatureSetByPortalItem(
p,
'PortalID2',
20,
['joinfield1','dt1'],
false
// Empty feature array and feat object to populate output
var features = [];
var feat;
// Iterate over features in main layer
for (var f in fs) {
// grab related records for feature
// var rel = FeatureSetByRelationshipName(
// f,
// 'related_table',
// ['joinfield1', 'dt1'],
// false
// create pivot? of years from imagery flight data table related to site_p features
// for(var r in )
//add features to output array
feat = {
attributes: {
JoinField: f['joinfield1'],
Namefield: f['featurename'],
LocationField: f['locationfield'],
// loop through years to create columns for last 10 years using a rolling count to keep format as Now -10
// Year1-Year10: (year >= Year(Now()) - 10)
Push(features, feat);
//create/populate output dictionary
var fs_dict = {
'fields': [
{name: 'joinfield1', type: 'esriFieldTypeString'},
{name: 'Namefield', type: 'esriFieldTypeString'},
{name: 'locationfield', type: 'esriFieldTypeString'},
'geometryType': '',
'features': features
//dashboard indicator has to process results as a FeatureSet
return FeatureSet(Text(fs_dict))
//sql statement from MS Access I'm trying to replicate:
//TRANSFORM IIf(Count([flight_year])>0,"X","") AS Expr1
//SELECT Installation_list.region, Installation_list.state_abbrev, Installation_list.installation_name
//FROM Installation_list INNER JOIN [_Gap Analyses part1] ON Installation_list.instln_id=[_Gap Analyses part1].instln_id
//GROUP BY Installation_list.region, Installation_list.state_abbrev, Installation_list.installation_name
//ORDER BY Installation_list.state_abbrev, Installation_list.installation_name
//PIVOT [_Gap Analyses part1].flight_year;
