Hi there,
Is it possible to have create a custom role in which the user doen not have the privilege to create a token via REST?
If that is the case how can I test for that, using the sef or username REST API endpoint?
Itay
I don't think this is possible, since the sign-in process uses the generate token operation in the background to authenticate the user. If a user couldn't generate a token, it would not be able to sign in. Here are the Privileges that can be assigned to custom roles in ArcGIS Online.
That makes sense (just wanted to verify it) and I take it that this also applies to sing in with oauth2 + PKCE, right?
I would think so, but I can't say for sure.
Well thanks anyway 👍
