Onvolledige mozaïek over het meer. Rastercellen rond het gat zijn wazig. <\/P>
Ik heb geprobeerd de instellingen te wijzigen, maar de lege cellen verschijnen toch.<\/P>
Iemand die dezelfde fout heeft gehad en een oplossing heeft? <\/P>
Lakes can be difficult, tried addressed with water body maskhttps://doc.arcgis.com/en/drone2map/latest/help/waterbody-mask.htm
Nice 🙂 many thanks for the feedback!
It worked with water body mask and processing it again. Thanks for the help
Hi @PeterLarsen,Sorry I missed your email I was out sick last week. I saw you posted here on the community forums as well and the image you shared here provides me with a bit more insight to the reconstruction issues going on with the project.
Looking at the flight lines and image collections for the flight there doesn’t seem to be any uniformity. By this I mean that the overlap between images is very erratic and there are large gaps between image collections. Is this how the flight was flown or are you missing images from the flight?
If you are missing images that Drone2Map didn’t import then we can attempt to look into why. Otherwise, my suspicion is the hole is being cause by poor overlap between images. If you look at the processing report for the project and review the graphic that depicts image overlap do you also see a hole there?Regards,Mark
