I have a form that includes a repeat for inspections that follow an initial site visit. A couple of things I am trying to solve that I think i know the answers two but would like to get confirmation:
You can get the index of a repeat using position(..)
I always make each inspection a form. Works out way better for editor tracking and all that. Plus location on each form etc. Editing past records and adding a repeat tends to not go well.
Have a parent layer that is your inspection sites in Field Maps then launch 123 forms from link passing the key over then it all links up.
Then you can use Arcade for totals and all that in the web map.
Little bit more advanced workflow but it has been a winner. Hope that helps
Appreciate your insight, I think this may be the best approach ultimately. Trying to drive everything from the survey may be too complicated..
