When I run command to setup a custom theme (arcgis styles create newtheme), I get error that file/directory does not exist. Is this a known issue, or any solution? Thanks.
estedError: Cannot glob `**/*`: ENOENT: no such file or directory, stat 'C:\Users\<usernamde>\AppData\Roaming\npm\node_modules\@arcgis\cli\node_modules\arcgis-js-api\assets\esri\themes\base'
I broke it. Try with latest 4.25.2 patch just updated. Note, this uses the 4.25 release of the Maps SDK. It will be updated for 4.27 at the next release as some other changes are coming as well.
