Hi. I'm using current version of ArcGIS Pro. I have a city boundary. I am trying to make a 1 mile buffer around it, and then create a 1000 x 1000 foot grid overlaid over the boundary. I have my units set in my document to feet.
The buffer command has an option where you can choose units, which I've chosen miles. But when I run it and measure it, the actual distance comes out to about 1.3 miles, which is about 2 km.
When I run the fishnet command, it does not have an option where you can select units but I believe it uses the project units. When I run it and measure it, though, it comes out to 3,280 x 3,280 feet, which is actually a square kilometer.
I'm probably missing something obvious but as far as I know everything in the project is set to Imperial units. Thanks in advance.
