Hi all--
Main issue: Editor tracking is no longer recording user names and dates of the create or edit fields.
I have custom/non-default names for create and editor tracking fields, set up in ArcGIS Pro and published as a web feature layer to Portal 10.9.1. I can't change these field names. They were working for a long time, and then we needed to disable editor tracking, and when it was re-enabled we found that editor tracking no longer works. This is my best guess as to what happened and it's possible that something else has occurred, but I don't know what that might be.
Has anyone had issues with editor tracking no longer working in Portal, even when it's showing as fully set up in Settings? I would really like to avoid re-publishing my feature layers if possible.
Editor tracking isn't working in data created in the Field Maps and Survey123 apps, as well as through a Web App designed for editing the data.
One other piece of information, if it's relevant - this is occurring in multiple View Layers based off of a single Feature Layer.
Thank you in advance!
