I have built a feature report based on Survey123 data and need to change a date to text based on the year of the date. If the date has a year of 9999, I want to replace the full date with text. Is this something that is possible?
Hi @StevenHughes44,You could do this by using a conditional report element and the format method to return the year.For example:
${if (date1 |format:”YYYY”)==”9999”}
A year of 9999 was entered.
Thanks,-Barbara
Thank you for your help on this. When I use the element as written, I get an error stating the the end tag is unopened. If I load the template without the end tag, the report does generate with the element result of this:
@StevenHughes44 Can you provide the report template and XLSForm you're using?
I have attached the Word template for this feature report.
@StevenHughes44 Thanks for sending the template. It looks like you're missing a space after the "if".
