Hi
I use GitLab CI/CD in order to build the product version of an ArcGIS Pro AddIn.
Is It possible to change de DAML Date automatically in order to set the Date as the builing Date ?
Best Regards
Effectively, a small powershell script could do the job :
$xmlPath = "Config.daml" $xml = Get-Content -Path $xmlPath $currentDate = Get-Date -Format "M/d/yyyy h:mm:ss tt" $xml = $xml -replace '<Date>.*?</Date>', "<Date>$currentDate</Date>" Set-Content -Path $xmlPath -Value $xml
I have written small executable which changes date and version of add-in. Argument of executable is project path. Executable searches catalog for daml file and makes changes. You can set in project settings Pre-build event:
"..\UpdateAddInDate\bin\Release\UpdateAddInDate.exe" $(ProjectPath)
UpdateAddInDate.exe is my executable. Project of executable is located in the same solution with add-in
