encountered wasm error when setting up map view. can someone enlighten me if this is a sdk issue or is there some configuration I am missing out when doing the map publishing on arcgis pro?
Hi there,
The error "failed to execute compile of webassembly: Incorrect mime type. Expected application/wasm" - seems to be related to you not configuring your server to serve wasm content. Adding wasm hopefully will solve the issue.
Without a reproducible case it is not possible to say what the issue is for sure. Is possible for you to share your service or a simple test app that throws this error? Thanks
Hi UndralBatsukh,
My map is hosted in a no internet zone, unable to provide the map service but this is how i initialize my mapview
const [view, setView] = useState<MapView | null>(null); const gl1 = new GraphicsLayer({ id: "gl1" }); useEffect(() => { const wmsLayer = new WMSLayer({ url: mapUrl, }); const baseMap = new BaseMap({ baseLayers: [wmsLayer] }); const map = new Map({ basemap: baseMap }); setView(new MapView({ map: map, container: "viewDiv", spatialReference: { wkid: 4326 } }); map.add(gl1); const pointGraphic = new Graphic({ geometry: new Point({ longitude: 103.9716, latitude: 1.35788, spatialReference: { wkid: 4326 } }), symbol: new SimpleMarkerSymbol({ style: "circle", size: "10px" color: [266, 119, 40], outline: { color: [0, 0, 0], width: 3 } }) }); gl1.add(pointGraphic); }, []);
Based on the above code snippet, the error is always encountered when I do a mapview. Not sure if it's because of this error hence my graphics can never be shown.
Any help would be much appreciated.
