Hi there,
I am having issues exporting my map from Mapviwer. I followed the steps to print, however, exporting is unsuccessful every time. All I can see is a red x beside the file name and a message saying “An error occurred while exporting the web map”. Any help with this issue would be greatly appreciated!
Are you able to share the map?
can you share the configuration of the print like size and include legend?
Thanks!
Hi Russ,
Attached is a screenshot of the information you requested! Thank you so much for the help.
Cheers
If you can share the map that will help see if I can reproduce it. My samples were working as expected.
JaxonReid, did you ever figure out a solution for this? I am having the same issue.
If you can share the map we can look to see where the print service might be failing.
I'm having the same issue. Tried different Page Setups, changed the DPI (higher and lower), made the file name shorter, turned off more layers. Still failing. Very frustrating, hope we get an answer on what's going on soon. Maybe it's the types of layers/source of where the data is coming from that is causing the issue? I feel like I might just give up on Map Viewer and just go with Classic, it seems to have less bugs.
If you can share a map that reproduces the issue then I can take a look. If you are seeing other issues please submit a support ticket or post on the community.
Here is a link to the web map: Review (arcgis.com)
I was trying to print with only a few layers turned on: museum, museum buffer, and 3-4 other layers just to test what was working (not too important which ones at the moment just for testing).
Thanks for your help.
Same issue here. I've tried to export in all formats. 96 DPI, 1000 x 1000 aspect ratio at the "City" Bookmark.https://duvalldecker-2.maps.arcgis.com/apps/mapviewer/index.html?webmap=719e50ea3d1f45bdbb395d23a892c630
I have the same issue am wondering how prevalent this issue is for ArcGIS Online users
Yesterday I was able to "print" i.e. export my map when I lowered my resolution so far as to be unusably bad
