In Pro 2.95 I can successfully create a tpk file but when I try it in Pro 3.1 with the same input and settings it gives the error "001461: failed to package tiles". Any ideas why?
This didn't apply to your case?
001461: Failed to package tiles.—ArcGIS Pro | Documentation
DescriptionThe cache geoprocessing tool failed to package tiles successfully.
SolutionVerify that the Target Cache Directory and the ArcGIS output directory has available disk space for the TILE PACKAGE.
Interesting...in my review of internal support cases, a customer had a similar issue. What they did to resolve the case was clip the raster first using the Clip Raster GP tool before packaging. Then use your worlkflow again to create the *.tpk. What is the result?
I have a similar problem as the above user did, and I changed my target cache directory and clipped the image in question. Neither solved my problem or changed the error message. Any other solution ideas, or ways to troubleshoot?
I am having a similar issue.
I keep getting "001461: failed to package tiles" even though I have 2 Terabytes of storage available.
Same error and I'm doing a small test area at small scales. I'd be surprised if disk space is the issue.
I also ran into this problem creating a tile package for a large raster. 001461 was my only error. After a lot of toying around (changing the output file location, clipping the raster, creating multiple packages, trying all manner of projections, changing the package type, tweaking every setting, crying), I finally had success after simply leaving the "Area of Interest" field in the tool blank.
I don't know if that will help any of you but I thought I'd give my 2 cents.
Thank you for posting this. This appears to be BUG-000163419 - "The error message, "ERROR 001461: Failed to package tiles" is returned if the 'Area of Interest' parameter is specified when using the Create Map Tile Package tool." It's currently "under review" by the ArcGIS Pro Dev Team.
I have also ran into this problem and applying the workaround BUG-000163419 for ArcGIS Pro (esri.com) the error still occurs, I have not put any "Area of Interest" or "Extent" and it still fails. I can create a Vector Tile Package with no issue using the same parameters.
I only get this error message when the Area of Interest input feature is in a different projection to the output tile package. When the "Package for ArcGIS Online" option is selected, the Area of Interest input feature projection needs to be WGS 1984 Web Mercator (auxiliary sphere) (EPSG 3857).
I'm on 3.1.2.
@Merritt and @ThomasPe - one thing I saw on the internals related to this question is building raster pyramids seem to fix the issue that other users were experiencing. I'd recommend trying this workflow and see if the error message returns.
There looks to be an update on the BUG article from 7/30/24 that provides a workaround:
Remove the feature from the Area of Interest parameter and put it in the Extent parameter.
However, the Extent parameter does not honor the extent boundary.
https://support.esri.com/en-us/bug/the-error-message-error-001461-failed-to-package-tiles-bug-000163419
I had the same issue and the workaround worked for me.
This may not work for you, I'm a bit of a layman in the complexities of how these processes work but I found that when I was hitting this error it was typically triggering at the parallel processing step. I set the Parallel Processing Factor environment parameter to 0 and it ran successfully.
... and worked for me, too.
This fixed it for me, I installed the new version 3.5.2 and then got a different error 003713, that mentioned parallel processing, so I tried 66 (instead of suggested 50), then 0, 0 worked! well it's working for now and hopefully will make it all the way!
