Hi BrentIn regards to your first issue:After data loading, are you not seeing the fabric Lines feature class being populated with COGO attributes? Your source lines "_arc" (that are being loaded into the fabric) do not need to have COGO attributes - if there are none the loader will automatically generate them from the line geometry and populate the fabric Lines feature class with COGO attributesIn regards to your second issue, this is a known limit for the loader and we are currently working on it. However we do have an AddIn that will generate linepoints for you from a selection of fabric parcels. I can email that to you if you likeChristine
Brent, there is a new add-in to merge parcel lines and then automatically generate line-points. It's on the land records blog, please feel free to add any comments.http://blogs.esri.com/Dev/blogs/localgovernment/default.aspxhttp://blogs.esri.com/Dev/blogs/localgovernment/archive/2010/07/28/Parcel-Editor-Add_2D00_In-Enhances-Parcel-Management-in-ArcGIS-10.aspxThanksChris
