What is going on?
It is a slow process using the Calculate Field tool in ArcGIS Pro with a hosted feature service.
This can rapidly be sped up using a combination of ArcPy and ArcGIS for Python API.
Use ArcPy to create a dictionary of your gdb data with the join key field as the key in the dictionary and the other attributes as a list for the dictionary value.
Use ArcGIS for Python API to update your feature service data. Workflow could look similar to below.
from arcgis import GIS import arcpy fc = r"path\to\gdb\fc" ## connect to AGOL agol = GIS("home") # feature service item from AGOL item = agol.content.get("FS_ITEM_ID") # get the layer object by layer name in the feature servic lyr = [lyr for lyr in item.layers if lyr.properties.name == "NAME_OF_LAYER_TO_UPDATE"][0] # create join dictionary to be used below join_dict = {} with arcpy.da.SearchCursor(fc, ["KEYFIELDNAME1", "FIELDNAME2", "FIELDNAME3", "FIELDNAME4", "FIELDNAME5"]) as cursor: for row in cursor: join_dict[row[0]] = [row[1], row[2], row[3], row[4]] # querying the layer to return a feature set object query = lyr.query() # populating field edits for layer update and field calculations edit = [f for f in query.features] for f in edit: join_key = f.attributes["KEYFIELDNAME1"] if join_key in join_dict: f.attributes["FIELDNAME2"] = join_dict[join_key][0] f.attributes["FIELDNAME3"] = join_dict[join_key][1] f.attributes["FIELDNAME4"] = join_dict[join_key][2] f.attributes["FIELDNAME5"] = join_dict[join_key][3] # applying field calculation updates to the layer print(lyr.edit_features(updates=edit))
Use SQL in the calculate field tool. Calculating 10,000-30,000 records will go from 2 hours (arcade) to a matter of minutes (SQL). It's highlighted in the documentation:
https://doc.arcgis.com/en/arcgis-online/manage-data/calculate-fields.htm
I believe it'll be faster if the 'undo' option is disabled, so the edits are committed immediately. I don't have a reference to back this up.
Far superior! Forgot about that one. It will reduce updating 10000 records in a hosted feature service from hours to seconds. One of the versions of ArcGIS Pro (in the 2.6 series) kept crashing on us when using SQL in the Calculate Field tool and we used the code in my previous post to overcome at the time.
I have a join, so my only options are Python and Arcade.
Calculation options
@GISUser74305830
The Python script is a great alternative so. It will be a lot faster than the CalculateField tool when using a Feature Service in ArcGIS Pro.
I finally dug into this and applied it and it worked perfectly! Thank you very much!
What is duct_dict here? Should I create an empty dictionary with that name?
Apologies, it was a copy and paste job from one of my workflows and forgot to replace. Code has been updated to reflect.
