I can't turn on this "enable theming" option. If I turn on and restart, it automatically turned off again.tried run as admin, no luck
I just want to turn on dark modeThank you
Hi @GunSikKim,
Theming is currenlty not available in CE. Everytime you set this option it will be disabled again on startup.
I interpret your post as feature request for a dark mode, so I'll move it to the ideas forum.
CheersJonas
Thank you for the answer!
With CityEngine 2023.1 there is now an option to switch the UI between a light and dark theme:Appearance preferences—ArcGIS CityEngine Resources | Documentation
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
