We're running into the following issue:
- Add a feature layer view to a web scene. Feature layer view exposes some of the fields in its feature layer. The feature layer has a few hundred features in it.
- The exposed fields are based on lists in the feature layer's fields.
- We set to feature layer's edit settings to Enable Edits, Adds, Deletes, Updates.
- We set the feature layer view's edit settings to Enable Edits, Update attributes only.
- In the web scene, we set the main attribute to visualize to one of the fields with a list (a UVR on a "type" field).
At this point, we can go into edit mode, select a feature, and update a feature in the scene by clicking the dropdown in the edit feature pane.
However, if we:
- Go back to layer properties and configure popups.
- Remove 1 of the fields
- RESULT: the dropdown become read-only in the edit feature pane. We can still select them, but we cannot change the selected feature attributes any longer.
Any ideas? Don't use feature layer views in the scene viewer?
Thanks!
