I`m trying to run a forest-based regression in ArcGis Pro 3.0.3 with the Forest-based classification and regression tool (Spatial Statistics). I am searching for an output-option to create plots for marginal effects. In R, you would use Partial Dependence Plots (PDP) or Accumulated Local Effects (ALE) plots. Is there an option to create partial dependence plots with ArcGis Pro Tools?
The tool itself is great, as it lets you easily combine feature, raster and distance-based data, which you would have to manually create and combine in R. So it would be great, if I could use ArcGis for the whole process including plots.
Thank you for any insights or help on this.
