I wanted to ask about some widget options, if it its available in the current version of the Experience builder.
I would like to create something like this: Land cover atlas
When you land on a page - click Launch and pop-up window appear with filters.
You can filter your data there and then click "get started". Then you land on a page where you filters are applied to a map and other widgets. You can also reset the filters on the page if needed.
I cannot find an option to "carry over" my filters from pop-up window to a page with a map.
After I set up my filters in the window and land to the map page my filters are lost and I see all the data again (no selection).
Is there an option to connect pop-up window with data filters to a map and actually see filtered results on a map?
Thank you!
