Is there a Portal setting to increase the resolution of portal web maps/apps. The same vector features on ArcGIS Pro Desktop are significantly higher resolution than the same on web maps/apps. An example is a tilted line in a web map shows noticeable zig zags. This image is stretched for discussion purposes, but clearly noticeable when not stretched also.
Thank you,
Tyler
