Looking for a python-way to check the existence of the following as part of a QA script:
I would do something like this in Python but there might be better ways:
fields_ls = arcpy.ListFields(input_layer) for f in fields_ls: if f.defaultValue == 'whatever': pass else: print(f'The defualt value for {f.name} is not equal whatever') if f.isNullable: print(f.name, 'nullable') if f.required: print(f.name, 'req')
you can access other attributes from the field object too:
f.aliasNamef.baseName f.editable #boolf.lengthf.type
Generally one good way to check the possible attributes/methods to use on an object in Python is to to pass it to the dir() like this:
dir(fields_ls[1])
and it prints all those for you!
UPDATE: The way I did it was just to give you the idea how to access those info but was not scalable to check for default values of multiple fields. You should have a list or dictionary of default values to pass along. (The way @Anonymous User suggested in the comments is great!)
This should get you started. Change out the defaults per field type in the dictionary.
import datetime # Create a list of fields using the ListFields function fields = arcpy.ListFields(in_Table) defaultVal = {'Blob': 'stuff', 'Date': datetime.datetime.now(), 'Double': 54.2, 'Geometry': 'Geometry', 'GlobalID': 'Global ID', 'Guid': 'Guid', 'Integer': 23, 'OID': 'Object ID', 'Raster': 'Raster', 'Single': 1, 'SmallInteger': 3, 'String': 'Text'} # Iterate through the list of fields for field in fields: # Not sure what Default value you are checking, but if they are different # for field types, you can set a dictionary and get it from there. print(f"Type: {field.type}") if field.defaultValue != defaultVal.get(field.defaultValue): # second param there is the defualt return if the key isnt found in the dictionary. print(f"Default Value: {field.defaultValue}") if field.isNullable: # True or False print(f"Is Nullable: {field.isNullable}") if field.required: # True or False print(f"Is Required: {field.required}")
