Add a transparency option either in basemap settings or in the layer settings when imagery from ArcGIS Online is added to the contents.
@YongweiKang 1.18So, it turns out the imagery layer I added was actually a "Web Map" <facepalm>. When the imagery is actually an image service, the Appearance tab is there no problem! 😄 Thanks for the help!
@GISAdminSHN I'm glad to hear that the ground transparency setting works for you. If the added layer shows up in the table of contents, and it is an imagery layer, the appearance tab in the properties should show up. See the below screenshot and the test data.
https://www.arcgis.com/home/item.html?id=aa9c87d6f17b452296252bd75005f6a4
Which version of Earth are you using? I'm sure we have supported it for a long time. But feel free to use our latest version 1.18.
Best,
Yongwei
@YongweiKang thanks! The ground transparency setting works for me. When I add the imagery through add data so that it shows up in the table of contents, there is no appearance tab in the properties (probably because it treats it as a basemap even though it's now in the table of contents as well.)
There are 2 ways to change the layer transparency:
Do these two options meet your needs?
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
