WorkspaceInfo info = WorkspaceInfo.CreateSDEConnectionFromFilePath(..) LocalFeatureService lfs = new LocalFeatureService() lfs.getDynamicWorkspaces().add(info) ArcGISLocalFeatureLayer lfl = new ArcGISLocalFeatureLayer(); lfl.setUrl(lfs.getUrl());
// create connection to the sde feature store using sde connection file final WorkspaceInfo info = WorkspaceInfo.CreateSDEConnection("test", "feature.sde"); // try to create a new feature service using the blank map pack final LocalFeatureService lfs = new LocalFeatureService("mpk_blank.mpk"); lfs.getDynamicWorkspaces().add(info); lfs.start(); // create a feature layer using the local service final ArcGISFeatureLayer layer = new ArcGISFeatureLayer(lfs.getUrlFeatureService());
Essentially, as the ESRI Australia blog explains, Runtime acts like a mini local web server ("...uses an embedded web server to create/communicate with worker processes that do things like draw map..."). You interact with this embedded web server's Feature Services based on your SDE connections (or whatever datasource you have, e.g. shapefile) via SOAP, not with the data "directly".
