Greetings,I'm still fairly new to using the arcpy.mapping functions. I want to add a FeatureClass to my map document which is open.In looking at other forum threads and reading help, I tried the following code:import arcpy import arcpy.mapping import os GeoDatabaseName = "G:\Documents\GIS\HydstraData\HydstraMeasurementsDeep\HydstraMeasurementsDeep_GroundwaterElevation_Daily_Contours_20130625_20120731.gdb" ##Reference the map document in memory. mxd = arcpy.mapping.MapDocument(r"G:\Documents\GIS\HydstraData\Contours_20131223.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] print df FeatureClassToAdd = os.path.join(GeoDatabaseName,"AllPoints") print FeatureClassToAdd tempLayer = "layer" ## Make a layer from the feature class arcpy.MakeFeatureLayer_management(FeatureClassToAdd,tempLayer) addLayer = arcpy.Layer(tempLayer) arcpy.mapping.AddLayer(df, addLayer, "AUTO_ARRANGE") arcpy.RefreshTOC()
This is the result I get back in my Python Shell windowing when I run the script in IDLE:<geoprocessing Data Frame object object at 0x02C57368>G:\Documents\GIS\HydstraData\HydstraMeasurementsDeep\HydstraMeasurementsDeep_GroundwaterElevation_Daily_Contours_20130625_20120731.gdb\AllPointsTraceback (most recent call last): File "G:/Documents/GIS/HydstraData/UpdateMxd.py", line 24, in <module> addLayer = arcpy.Layer(tempLayer)AttributeError: 'module' object has no attribute 'Layer'Any suggestions? Thanks for any help!Jon Mulder
