Hi all,
I am facing some ANR with my implement as below and the log for ANR point to our Arcgis map when getting the identify graphic overlay.
Could someone help to check for that?
Please let me know if you need further information
Implementation for touching listener:
onTouchListener =
object : DefaultMapViewOnTouchListener(context, this) {
override fun onSingleTapConfirmed(event: MotionEvent): Boolean {
val screenPoint =
android.graphics.Point(event.x.roundToInt(), event.y.roundToInt())
val identifyGraphic = mMapView.identifyGraphicsOverlayAsync(
graphicsOverlay,
screenPoint,
10.0,
false,
Int.MAX_VALUE
try {
val identifyGraphicsOverlayResult = identifyGraphic.get()
val graphics = identifyGraphicsOverlayResult.graphics
} catch(e: Exception){
// print log here
return super.onSingleTapConfirmed(event)
ANR log report:
libc.so
syscall + 28
1. libc.so
__futex_wait_ex(void volatile*, bool, int, bool, timespec const*) + 144
2. libc.so
pthread_cond_wait + 76
3. split_config.arm64_v8a.apk
std::__ndk1::condition_variable::wait(std::__ndk1::unique_lock<std::__ndk1::mutex>&) + 20
4. split_config.arm64_v8a.apk
(Missing BuildId 4d4a58df2fe1ee0c204b45b49389f1966c646580)
5. split_config.arm64_v8a.apk
6. split_config.arm64_v8a.apk
7. split_config.arm64_v8a.apk
8. split_config.arm64_v8a.apk
9. split_config.arm64_v8a.apk
10. split_config.arm64_v8a.apk
RT_Task_get + 32
11. split_config.arm64_v8a.apk
Java_com_esri_arcgisruntime_internal_jni_CoreTask_nativeGet + 20
com.esri.arcgisruntime.internal.jni.CoreTask.nativeGet (SourceFile)
com.esri.arcgisruntime.internal.jni.CoreTask.f (SourceFile:1)
com.esri.arcgisruntime.internal.concurrent.b.get (SourceFile:23)
.......setOnMapViewTouchListener$1.onSingleTapConfirmed
