I need to make a map of voronoi from polygons about a certain attribute in arcgis Pro, since it is an arcmap function and I need the same function in arcgis pro and I can't find it
But i need the local statistics, in this case you know another similar tool?
Hi, I just noticed that you were asking about creating a Voronoi Map from polygons rather than points.
If you just need the geometry of the Voronoi Map and do not need the local statistics, you can do the following:
This will give the same polygons as the Voronoi Map ESDA tool in ArcMap. Again, it will not have the local statistics, but it will create the same polygons.
Thanks, but Do you know another similar tool to voronoi map in Arcgis pro? or another idea that help me.
Hi Liliana,
Unfortunately, the Voronoi Map tool is not available in ArcGIS Pro. Most Exploratory Spatial Data Analysis (ESDA) tools from ArcMap are available as charts in ArcGIS Pro, but the Voronoi Map is not one of them.
-Eric Krause
Geostatistical Analyst anyone here able to contribute to Liliana's question?
Thank you!
Thiessen polygons only works with points, not with polygonsIn ArcmapWith Geostatistical Analysis -> explore data -> voronoi map.
Is this what you're looking for? Which function did you use in ArcMap?Create Thiessen Polygons—Help | ArcGIS Desktop
