Hello All,
I am looking to create a custom web application with the ArcGIS 4.x JS API with React. I would like to embed a Survey123 form to collect data from Users similar to the Survey Widget in Experience Builder.
Is it possible to integrate the Survey123 API as shown here: https://developers.arcgis.com/survey123/guide/embed-a-survey-using-javascript/#configure-a-survey-in-arcgis-experience-builder with this repo using the "@arcgis/core" with React and Vite? https://github.com/Esri/jsapi-resources/tree/main/esm-samples/jsapi-react
Or should I approach this a different way? Ideally I am looking to have the form load conditionally (i.e only when 1 layer is clicked on). I also am trying to pass(some) data from the clicked on layer to the Survey form.
All the Best,
Andrew
I was able to get this (sort of) working using Ionic and React - using Next might prove to be a bit more challenging though with default SSR and all that.
const SurveyPage: React.FC = () => { const containerRef = useRef<HTMLDivElement>(null); const { isSignedIn, portal } = useAuth(); useEffect(() => { // Run script loading and survey initialization only when signed in. if (!isSignedIn) return; // Function to load the Survey123 script dynamically const loadSurveyScript = () => { return new Promise<void>((resolve, reject) => { // If already loaded, resolve immediately. if ((window as any).Survey123WebForm) { resolve(); return; } const script = document.createElement('script'); script.src="https://survey123.arcgis.com/api/jsapi/"; script.onload = () => resolve(); script.onerror = () => reject(new Error("Failed to load Survey123 API")); document.head.appendChild(script); }); }; // eslint-disable-next-line @typescript-eslint/no-unused-vars let surveyInstance: any; loadSurveyScript() .then(() => { // Ensure the container exists and the Survey123WebForm global is available if (containerRef.current && (window as any).Survey123WebForm) { // Clear the container to avoid duplicate surveys containerRef.current.innerHTML = ""; surveyInstance = new (window as any).Survey123WebForm({ clientId: ArcGISConfig.auth.clientId, container: containerRef.current, itemId: "******", // eslint-disable-next-line @typescript-eslint/ban-ts-comment //@ts-expect-error token: portal?.credential.token, }); } }) .catch((error) => { console.error("Survey123 script failed to load:", error); }); // Cleanup on unmount return () => { if (containerRef.current) { containerRef.current.innerHTML = ""; } }; }, [isSignedIn, portal]); return ( <IonPage> <IonHeader> <IonToolbar> <IonButtons slot="start"> <IonMenuButton /> </IonButtons> <IonTitle>Survey</IonTitle> </IonToolbar> </IonHeader> <IonContent fullscreen> {/* Container for the Survey123 form */} {isSignedIn && <div ref={containerRef} id="formDiv" style={{ padding: '16px', height: '100vh' }} />} </IonContent> </IonPage> ); }; export default SurveyPage;
Have you found a better solution? I don't really like how 'non-Reactive' this is.Thanks,
Aidan
I'm trying to do something similar. I'm actually trying to integrate the S123 API with this newer sample by @ReneRubalcava: https://github.com/odoe/ds2024-arcgis-map-comps-next/ . Were you able to figure this out?
