Tesing the detect Gaps
#import arcpy module
import arcpy
#Chcek out any necessary to licnes
arcpy.CheckOutExtension("Calgary1_done")
#local variables set
setNetwork = r"G:\Jason Ma\2022Q3 HERE shapefiles\Corridors\Old corridors\Calgary1_done"
#event =
final_gaps_output= r"G:\Jason Ma\2022Q3 HERE shapefiles\Corridors\Old corridors\New_Gaps_Cal1"
#Detect the GAPS in the linear events
arcpy.env.overwriteOutput = 1
arcpy.DetectGapsForLinearEvents_locref(setNetwork, final_gaps_output)
Hello all staff of Esri,
I am trying to create a function which detect gaps within road layer, seems that the library from Arcpy is not reading the module correctly in of the arcpy functions:
Error:
Runtime error
File "<string>", line 18, in <module>
AttributeError: 'module' object has no attribute 'DetectGapsForLinearEvents_locref'
Any suggests and Help I glad to hear , Thanks you
