Trying to do a little more with ArcGIS Server logs. So I want access them programmatically.
Using FME to connect to my server/admin page for generating tokens:
myserver.domain:6443/arcgis/admin/generateToken
This is where I can grab a token manually in the browser. I can then plug that token as parameter in the query using FME (HTTP Caller) and - boom - I'm talking to ArcGIS Server.
But when I try to hit the above endpoint with a POST in FME (HTTP Caller) directly to get a token that way, I cannot get ArcGIS Server to send me one. All I get are errors. Other parameters I use (per instructions here) are:
client : requestip
f : json
and headers:
Content-type : application/x-www-form-urlencoded
Accept : text/plain
Putting username/password in the body, it cannot be found. If I put it in the query, I get a ""POST request should not contain username and password in the query string." Am I doing this wrong, or could this be related to BUG-000129762. it's unclear to me in the bug description if it's a Portal or AGOL issue. But since I'm on 10.9 and the bug references a 10.9.1 fix, I'm wondering.
