Does Power Automate only work with ArcGIS Online or can we use it with Enterprise?
thanks,
--gary
Hello @GaryBowles1,
You can use Microsoft Power Automate with your ArcGIS Enterprise organization you will just need to create a custom connector that points to your Enterprise organization. Please see this documentation for more details.
One of the most important considerations is the custom Survey123 connector for Power Automate does not support organizations configured with Integrated Windows Authentication (IWA) and since Power Automate needs to communicate with your organization the enterprise environment must be accessible over the internet.
Excellent! Working great.
I'm using Microsoft Power Automate to create flows and automate emails based on the questions in Survey123 in ArcGIS Enterprise environment. My flows have stopped working.I had Standard connection (free subscription) and not the non-Standard connection (paid subscription) of Microsoft Power Automate and the flows worked great the entire year of 2022. However, now the flows have stopped working. In the hopes of getting them to work again I turned off one of the flows, but now when I try to turn it back on it says, I do not have the non-Standard connection to make the flow work. The bottom line is, I never had the non-Standard connection last year but all the flows worked fine.I do not know what has gone wrong? Will I have to have the non-Standard connection to get the flows to work again? My state does not have the provision to get the non-Standard subscription. What do I need to do?
Have you faced the same issue and resolved it? Please let me know if this can be fixed.
Thank you very much for your input friends.
Abi
Hello @AbiDhakal,
I would suggest reaching out to Microsoft support to verify if your subscription meets the prerequisites to create a custom connector.
Please see this documentation for more information on prerequisites for custom connectors.
Thank you, Zach. I may have to reach out to Microsoft like you suggest.
Hi @ZacharySutherby
Is it only possible to use the custom connector for enterprise within the context of Survey123? For instance there is a PA ArcGIS connector to trigger when a record is added to a hosted feature layer. Is it possible to create an enterprise connector for the trigger? Much appreciated.
Are there any methods to connect Microsoft Power Automate to ArcGIS Enterprise for regular hosted feature layers vs just Survey123?
@m3 this is supposed to be coming any day now...see this thread
https://community.esri.com/t5/arcgis-for-power-automate-questions/can-arcgis-for-power-automate-be-used-with/m-p/1254537#M157
lol, that's my boss' thread 😄
Hi all,
I've tried following the steps here : https://support.esri.com/en-us/knowledge-base/how-to-create-an-arcgis-survey123-connector-for-microso-000025025. However, I'm still stuck at the step 7. I've tried to create a new connection and tried to sign with different administrator account but still failed.
Is there any suggestion to fix the issue?
Thanks.
@NurFarahHannanAhmadI think it only works with paid subscription of Power Automate now. If you have a paid subscription of Power Automate and it is still not working then this would be a good Esri tech support question.
Thank you,Abi
Hi @AbiDhakal I've tried using a paid subs of Power Automate and it works.
@NurFarahHannanAhmadI'm glad!
I keep getting this error when trying to create the connection:
I've tried using the new ArcGIS Enterprise connector using Set up the ArcGIS Enterprise connector—ArcGIS for Microsoft 365 | Documentation and creating a custom connection using with Survey123 directly using How To: Create an ArcGIS Survey123 Connector for Microsoft Power Automate for Use with Arc (esri.com).
Either way I get the same error.
@Becca_Unfortunately, I do not have access to Power Automate premium license and as such cannot test what you are experiencing.
