I'm still learning ArcGIS, but I immediately came upon an issue while trying to get everything set up. This is from the very first tutorial, as well.
The code is very simple. It simply displays a map.
from arcgis.gis import GIS
gis = GIS()
m = gis.map()
m
However, I'm getting an error message from this code.
FWIW, I installed everything using pip, and I'm in the virtualenvironment that everything was installed into using a jupyter notebook and vs code. I tried it in jupyter lab, just to make sure, but I got the same error.
AttributeError Traceback (most recent call last)
File c:\Users\AlastorBloode\SpanWalker App\ent\lib\site-packages\IPython\core\formatters.py:920, in IPythonDisplayFormatter.__call__(self, obj)
918 method = get_real_method(obj, self.print_method)
919 if method is not None:
--> 920 method()
921 return True
File c:\Users\AlastorBloode\SpanWalker App\ent\lib\site-packages\arcgis\widgets\_mapview\_mapview.py:948, in MapView._ipython_display_(self)
942 """Override the parent ipython display function that is called
943 whenever is displayed in the notebook. Display a blank area
944 below the map widget that can be controlled via a display handler
945 set to self._preview_image_display_handler.
946 """
947 self._setup_gis_properties(self.gis)
--> 948 super(MapView, self)._ipython_display_()
949 self._preview_image_display_handler = display(
950 HTML(self._assemble_img_preview_html_str("")),
951 display_id="preview-" + str(self._uuid),
952 )
953 self._preview_html_embed_display_handler = display(
954 HTML(self._assemble_html_embed_html_str("")),
955 display_id="preview-html-" + str(self._uuid),
956 )
AttributeError: 'super' object has no attribute '_ipython_display_'I'm not sure how to fix it, or if it's a known bug or if I'm just making some mistake somewhere, but any help would be highly appreciated.
