mxd = arcpy.mapping.MapDocument(r"X:\assr\carto\maps\Work_Map_Atlases\Residential_Atlases\Cycle_" + cycle_num + "_Atlas_temp.mxd") for page in Page_List: # Loop through Page_List Pg_Num =str(page) # Page number from Page_List pageID = mxd.dataDrivenPages.getPageIDFromName(Pg_Num) # Using the page number, get the pageID for the MXD mxd.dataDrivenPages.currentPageID = pageID # Set the current page in the DDP atlas to the pageID fieldValue_str = str(mxd.dataDrivenPages.pageRow.TRSQ) # Pull the TRSQ field info from the active Index page pageID_str = str(pageID) # Convert pageID to a string to use in the PDF output name string arcpy.mapping.ExportToPDF(mxd, folder_path + folder_name + "\\" + benchmark_folder_yr + "_" + I + "\\" + fieldValue_str + "_" + pageID_str + ".pdf", "PAGE_LAYOUT")
