I've searched similar posts but can't find an answer to this issue, I have a survey and when I go to edit or view records in the Inbox, most of the fields are empty. These fields are not in a repeat although there is a repeat near the bottom of the survey and I have "query allowUpdates=true" in the bind::esri:parameters column. for that repeat.
There are 40 "groups" of questions for asset condition ratings, and they get existing data from CSV files. Each group is only visible if there is data for that asset. i.e. if there are only 10 assets at a site, then only 10 of the 40 groups of questions is visible.
Each group of questions has a rating with an appearance of "likert", a comment field and a photo field, all of these appear to be empty when viewing or editing via the inbox. The only fields that have data are the few at the start with date, observer and site name. I am using v3.16.114 of Survey123 Desktop Field App and v3.16.110 of Survey123 Connect which I think are the latest.
I've attached the xlsx form and 5 CSV files from the Media folder.
Any help would be a great Christmas present!! Thanks.
