Once you deploy you starting making it your own. Updating maps, changing labels, rearranging the dashboard, adding back in those two or three extra fields in a layer here or there.
And then, the solution is updated!
Instead of weeks of work to reload all your data and update all the settings what if the solutions could see that you have a prior version installed and just make the changes to the fields, layers, and tables that were changed?
I'm looking at you Water Distribution Data Management Solution and your wild changelog of what seems to be tiny changes.
| Version | Description |
2.0 | - Manufacturer and Model fields were added to the Hydrant Maintenance Inspection table to support the Water Utility Hydrant Inspections solution.
1.3 | - The Minimal Gallery app has been removed from the solution item.
1.2 | - Name changed from Water Distribution Data Management for ArcGIS Online to Water Distribution Data Management.
