Hello,I'm having difficulty creating an accurate buffer of a polygon. I can request the buffered geometry and display the respective graphic just fine, but when I measure the distance of the buffer to the original polygon (using the esri measure dijit) the distance is not the same as my input distance.When in ArcMap, I buffer the same polygon by the same distance and I get a different buffer than I get from the js Geometry Service so I'm fairly certain that my problem lies with the Geometry Service not the Measurement dijit.var buffDist = dom.byId("BuffDist").value; var gph = graphicArray[0]; var gs = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var params = new BufferParameters(); params.distances = [buffDist]; params.unit = GeometryService.UNIT_KILOMETER; params.bufferSpatialReference = map.spatialReference; params.outSpatialReference = map.spatialReference; params.geometries = [gph.geometry]; gs.buffer(params, function (result) {});My workflow is quite standard. My input geometries are from a graphic that I received from a user click on the map. The map spatial reference is web mercator (102100), which I thought might be causing the problem so I have been experimenting with converting web mercator to geographic but I have not had any luck getting a successful return from the Geometry Service.Anyone have any ideas what is causing the buffer to be wrong?
