arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.Failed to execute (PolygonToRaster).
thanks for the reply. I avoid this problem by saving the output to gdb. I used the latest version.
I did, thanks for the reply. I avoid this problem by saving output to gdb
@MingHan which version of ArcGIS Pro are you using?
Did you specify a folder for the output of the *.tif or was the output going to a geodatabase?
*,tif files must go into a folder.
Hmm, problem solved by remove ".tif" ........
Here is the example data and script. It is very weird to me. Any one can help? Thanks
