Is there a way to remove the thousands separators from the Data View on ArcGIS Online/ArcGIS Hub?
The old method of deselecting the thousands separators option for the pop-up viewer (see https://community.esri.com/t5/arcgis-hub-questions/removing-thousand-separator-arcgis-online/m-p/849630) no longer works.
I can only move them, not delete.
It should have been posted to the ArcGIS Online community, not ArcGIS Hub. I am currently posting this question to that community so you can remove this one.
So, not related to popups? Which community, I can move this post for you.
R_
Face palm. Just realized I posted this in the wrong community. I keep forgetting ArcGIS Hub and ArcGIS Online are not the same thing. I will post this question in the appropriate community.
Not sure what the Data View on Online/Hub is, but the post you linked is refering to the popup configuration on the old "Classic" Map Viewer.
If you are wanting the same thing with the "New" Map Viewer, then you configure that with the Configure Fields button on the right (just below the popup config button).
See the "Configure Fields" part of this documentation.
