I created an Experience where I want to have multiple (6) maps all have a linked extent. The navigation at the top of my page moves through the different maps, but I want the user to be able to zoom in and pan around on the map, then click to a different map and see the exact same zoom/extent as the previous map. This was possible on the old 'Story Map Series Application' tab option where all maps are linked. In experience builder it should be possible using the 'Actions' functionality and using the 'Zoom to Extent', but when I do that it sometimes works, but also sometimes it doesn't and the maps starts jumping all around without the user doing anything (usually zooming out more and more). It's to the point it's unusable. I also noticed that in the old story map series app, movement between maps is seamless, whereas, in experience builder, when you change to the next map, it starts at it's original extent, then eventually zooms to the other maps extent (when it's actually working). There is quite a bit of lag to it. Is there a bug or issue with the zoom to functionality acting up? Is there a way to rectify this?
I'll also note, I tried re-building this in the new story maps (where linked map extents don't seem possible) and other applications, but noting is giving me what I want. Most other options ESRI has is limited to just comparing 2 maps.
Thanks in advance.
