Error #100160 is occurring while importing longitudinal and latitudinal as shapefile.
I did all the necessary procedures.
Check the screenshot
Yes, I kept those as Northing and Easting.
I assigned a new P/S from the list but the same happened.
the points are not in decimal degrees, so you have to specify an appropriate coordinate system. perhaps it was a projected source like web mercator? Check
Dan, A C/S was fed. (Check the screenshot). The inputs are fine as they worked on ArcMap standalone.
The attached ZIP contains the XLS file.
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
an invalid coordinate system was specified according to the help. Show the table and the inputs to the tool dialog to track down the error
