In creating a feature in a feature class or shapefile, you have to select which layer you want to edit. If you have data in your map from different folders or workspaces, you'll be asked which feature in the folder or workspace you want to edit, so if you want to edit a shapefile in C:\Data, choose that workspace to edit in. What I find easiest is to right click on a feature layer in your map and go to Edit Features > Start Editing. This will enable editing for that layer, (and any other layer in the workspace). Next, you have to select the template under the Create Features window, and select a construction type.
Susan,To create a feature class go to the Catalog window (or ArcCatalog) and then Data Management Tools > Feature Class > Create Feature Class.The message window that you're getting is normal for editing or creating features within an existing feature class. Select an editable fc and you're on your way.Scott
