Raster image services published in ArcGIS online and displayed with map viewer are configured incorrectly and can not be modified by the user. If you look at the first attached link (rasterimage.png), the data is from a minimum of -174.913 and goes to a maximum of 80.6847 but the range is shown as 80.6847 - -174.913. The range order should be flipped from min to max. Better yet, the range values should be placed bottom to top rather than left to right. I copied a second image below (arcpro.png) from arcpro to show how it should look in arcgis online. The client I am doing work for actually had this complaint.
https://iili.io/H9cMhL7.png
YES!I'm having the exact same issue with my rasters published as map image services (High-Low, okay but which end of the ramp is high?)Make legends in AGOL more configurable!
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
