Hello Matshopp,
Do you mind to share you code? I'm trying also to implement this function.
Regards,
Dilson
Thank you so much Matt. I was stuck on the same issue too. your post helped me solve the "point-click-update-latlong-coordinate" thing. however though i see another slight problem when the user moves the point. the coordinate wont save. as the coordinate save only "on click". unless of course if the user clicks on the point again after the "moves". is this problem apply to yours too? here is my codes: //-My changes start-// public static const LAT:String = "lat"; public static const LON:String = "lon"; public var longitude:String; public var latitude:String; import widgets.Coordinate.DegToDMS; import mx.formatters.NumberBaseRoundType; private function MapClicked(event:MouseEvent):void { var mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY); const latlong:MapPoint = WebMercatorUtil.webMercatorToGeographic(mapPoint) as MapPoint; longitude = DegToDMS.format(latlong.x,"lon"); latitude = DegToDMS.format(latlong.y,"lat"); } //-My changes end-// private function basewidget_widgetConfigLoaded(event:Event):void { numberFormatter.precision = parseFloat("6"); //-My changes-// map.addEventListener(MapMouseEvent.MAP_CLICK, MapClicked); //-My changes-// map.addEventListener(MouseEvent.MOUSE_MOVE, MapClicked); // hide map infowindow if any map.infoWindow.hide(); ......................
//-My changes start-// public static const LAT:String = "lat"; public static const LON:String = "lon"; public var longitude:String; public var latitude:String; import widgets.Coordinate.DegToDMS; import mx.formatters.NumberBaseRoundType; private function MapClicked(event:MouseEvent):void { var mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY); const latlong:MapPoint = WebMercatorUtil.webMercatorToGeographic(mapPoint) as MapPoint; longitude = DegToDMS.format(latlong.x,"lon"); latitude = DegToDMS.format(latlong.y,"lat"); } //-My changes end-// private function basewidget_widgetConfigLoaded(event:Event):void { numberFormatter.precision = parseFloat("6"); //-My changes-// map.addEventListener(MapMouseEvent.MAP_CLICK, MapClicked); //-My changes-// // hide map infowindow if any map.infoWindow.hide(); if (configXML) { if (GeometryServiceSingleton.instance.url) // using GeometryServiceSingleton { ... ... ... } private function featureLayer_selectionComplete(event:FeatureLayerEvent):void { for each (var field:Field in event.target.layerDetails.fields) { if (field.type == Field.TYPE_DATE) { for each (var feature:Graphic in event.features) { var date:Date = new Date(feature.attributes[field.name]); if (date.milliseconds == 999) { date.milliseconds++; //Add 1ms to date values ending in 999 to workaround REST date bug feature.attributes[field.name] = date.time; } } } //-My changes start-// if (field.name == "Longitude") { //var feature:Graphic; feature.attributes[field.name] = longitude; event.featureLayer.applyEdits(null, [feature], null) } if (field.name == "Latitude") { //var feature:Graphic; feature.attributes[field.name] = latitude; event.featureLayer.applyEdits(null, [feature], null) } //-My changes end-// } }
<?xml version="1.0" encoding="utf-8"?> <!-- Copyright (c) 2010 Esri All rights reserved under the copyright laws of the United States and applicable international laws, treaties, and conventions. You may freely redistribute and use this sample code, with or without modification, provided you include the original copyright notice and use restrictions. See use restrictions in use_restrictions.txt. --> <!--- Custom skin class for the AttributeInspector component. --> <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:s="library://ns.adobe.com/flex/spark"> <fx:Metadata> /** * A strongly typed property that references the component to which this skin is applied. */ [HostComponent("com.esri.ags.components.AttributeInspector")] [Event(name="attachmentGroupClicked", type="flash.events.Event")] [Event(name="okButtonClicked", type="flash.events.Event")] </fx:Metadata> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.components.AttributeInspector; import mx.controls.Alert; protected function onGetGeometryButtonClick(event:MouseEvent):void { var ai:AttributeInspector = hostComponent as AttributeInspector; if (ai != null) { var af:Graphic = ai.activeFeature; if (af != null && af.geometry != null) { // so the "af.geometry" is that you need Alert.show(af.geometry.toString()); } else { Alert.show("AttributeInspector has no active features!"); } } else { Alert.show("AttributeInspector is null!"); } } ]]> </fx:Script> <fx:Script> <![CDATA[ import com.esri.ags.layers.FeatureLayer; import mx.containers.FormItem; import mx.containers.FormItemDirection; import mx.events.ChildExistenceChangedEvent; // configurable through the edit widget's config file [Bindable] public static var showAttachmentsText:String; [Bindable] public static var deleteLabel:String; [Bindable] public static var okLabel:String; private function attachmentGroup_clickHandler(event:MouseEvent):void { dispatchEvent(new Event("attachmentGroupClicked", true, true)); } protected function okButton_clickHandler(event:MouseEvent):void { dispatchEvent(new Event("okButtonClicked", true, true)); } protected function form_childAddHandler(event:ChildExistenceChangedEvent):void { var displayObject:DisplayObject = event.relatedObject; if (displayObject != null && displayObject is FormItem) { var formItem:FormItem = displayObject as FormItem; var labelValue:String = formItem.label; formItem.label = ""; var lbl:Label = new Label(); lbl.text = labelValue; formItem.addChildAt(lbl, 0); } } ]]> </fx:Script> <s:states> <s:State name="normal"/> <s:State name="disabled"/> <s:State name="invalid"/> </s:states> <s:layout> <s:VerticalLayout horizontalAlign="center"/> </s:layout> <!--- Form to display the attributes of the active feature. --> <mx:Form id="form" width="100%" height="100%" enabled.disabled="false" horizontalScrollPolicy="off" maxHeight="{hostComponent.getStyle('formMaxHeight')}" verticalScrollPolicy="auto" childAdd="form_childAddHandler(event)"> </mx:Form> <s:HGroup verticalAlign="middle"> <!--- Button to delete the active feature. --> <s:Button id="deleteButton" enabled.disabled="false" label="{deleteLabel}"/> <s:Button id="okButton" click="okButton_clickHandler(event)" enabled.disabled="false" label="{okLabel}"/> <s:Button label="Geometry?" click="onGetGeometryButtonClick(event)" /> </s:HGroup> <s:HGroup id="attachmentGroup" width="100%" height="100%" horizontalAlign="right" includeInLayout="{FeatureLayer(hostComponent.activeFeature.graphicsLayer).layerDetails.hasAttachments}" verticalAlign="middle" visible="{FeatureLayer(hostComponent.activeFeature.graphicsLayer).layerDetails.hasAttachments}"> <s:Label buttonMode="true" click="attachmentGroup_clickHandler(event)" fontWeight="bold" text="{showAttachmentsText}"/> <mx:Image id="img" width="25" height="25" buttonMode="true" click="attachmentGroup_clickHandler(event)" source="@Embed('/assets/images/edit_attachments.png')"/> </s:HGroup> </s:SparkSkin>
